Where can I buy this? - Druckversion
+--- Thema: Where can I buy this? (/showthread.php?tid=23803)
Where can I buy this? - MercedesW124 - 07.02.2014
Where can I buy this? It is placed on the transmission
MB Trac 1300 1981
[Bild: 1C90141D-E058-44B6-889C-49BBEB8DF551_zps2vkqcbto.jpg]
[Bild: DBA9ED6F-A2C5-4F08-8F99-AD972869D647_zpsejzebdvi.jpg]
[Bild: FBE8B369-99A5-4747-94AA-3258FD08DD11_zpsoahndwob.jpg]
[Bild: 272E9341-8125-42CD-8761-ECC46B6C528F_zpsxnxbw0lz.jpg]
RE: Where can I buy this? - Hartmut - 07.02.2014
http://www.schreyer-online.com/trac_ersatzteile_n_druckluft.htm
Umschaltventil:
Gänge 1-4 / 5-8
beim MB-trac 1300 - 1800
und beim UNIMOG
RE: Where can I buy this? - handeule - 07.02.2014
Hi, I think at the next mercedes workshop but as far as I remember it is made by Bosch. If you remove the mud you will see the Bosch number. May be you can order it also from Bosch or Wabco.
Best regards Marcus
RE: Where can I buy this? - MercedesW124 - 07.02.2014
It is only 2 part numbers on it.. As you see in the pictures
I need a new because this one is leaking air. From 8 to 0 bar air pressure takes only some hours
RE: Where can I buy this? - MB 800 - 07.02.2014
(07.02.2014, 22:48)handeule schrieb:  If you remove the mud you will see the Bosch number. May be you can order it also from Bosch or Wabco.
Best regards Marcus
Hello Christian.
You have to clean it up right here.
[Bild: attachment.php?aid=27006]
It´s the factory lable. Part-No. is almost mentioned there Wink
Best regards from Nueremberg
There is no more to clean. The text is worn away
RE: Where can I buy this? - Hobbyfahrer - 10.02.2014
Hello Christian.
take a look here -> https://www.trac-technik.de/Forum/showthread.php?tid=18837&pid=118772#pid118772
