1300 Turbo accelerator linkage/control - Druckversion
+--- Thema: 1300 Turbo accelerator linkage/control (/showthread.php?tid=33305)
1300 Turbo accelerator linkage/control - Tim1300Turbo - 17.10.2017
Greetings from Australia,
My MB Trac 1300 Turbo is very unresponsive in the throttle/accelerator control.
The air valve in the pedal footwell leeks air quite a bit, and the motor wont return to idle very quickly.
Should I try to source parts to fix the air controlled throttle or try and engineer a linkage system?
Parts are hard to come by here in Australia.
Thankyou in advance
Tim
RE: 1300 Turbo accelerator linkage/control - Roby - 17.10.2017
Hi Tim,
It is easier to repair the existing system and keeping the Trac in original state.
Here some Threads about the " Luftgas /pneumatisches Gas"
https://www.trac-technik.de/Forum/showthread.php?tid=19672&pid=123483#pid123483
https://www.trac-technik.de/Forum/showthread.php?tid=20639&pid=129401#pid129401
https://www.trac-technik.de/Forum/showthread.php?tid=819&pid=98707#pid98707 Post#20
Here you can buy the Mastercylinder or perhaps Bernd can make you an offer?
Greetings
RE: 1300 Turbo accelerator linkage/control - Tim1300Turbo - 18.10.2017
(17.10.2017, 18:24)Roby schrieb:  Hi Tim,
Greetings
Hi Roby,
Thankyou for the great information. I will see if the parts are available in Australia?
I would like to keep the TRAC as original as possible.
Greetings.
Tim
