Themen: 2
28.05.2014, 23:17
(Dieser Beitrag wurde zuletzt bearbeitet: 28.05.2014, 23:19 von
Hello!
I have the MB-trac 900 turbo, engine OM 314. I would like him increased strength, so I was wondering if l can replace the turbine to turbine from the MB-trac 1100?
Greetings from Slovenia!
Jakob
Themen: 34
Hi Jakob.
What did you mean with "turbine"? Do you mean the engine? It is possible to place the om 352/om 366 in the trac 900 but you have to be a very good mechanic ;-)...
https://www.trac-technik.de/Forum/showth...p?tid=2188
Otherwise you can "tune" your trac into an intercooler...
Look at this:
Greetings
Themen: 45
Ich glaube er meint ob er den turbolader vom 1100 beim om 314 reinbauen kann, damit er mehr leistung hat....
Viele Grüße Michel
Case Farmall 75C
Der neue nach dem Trac....
Themen: 45
29.05.2014, 15:44
(Dieser Beitrag wurde zuletzt bearbeitet: 29.05.2014, 19:32 von
Haumoaster.)
Hi,
My MB trac 900 turbo year 1981 had around 95 PS. I have not an intercooler.
I had my diesel injetion pump new calibrated.
The rest is fully originally.
Sorry my english is not very good...
Viele Grüße Michel
Case Farmall 75C
Themen: 34
Hi Jakob.
I dont´t know, if you can change the turbine into a turbine from the 1100, cause there is another engine placed... I think the easilyst method to get more power is the new calibration of the diesel injection. Maybe you´ve got an Bosch service Station near your town...
Greetings
