i need a rear axel for my mb trac 700 1981
Suche - i need a rear axle for a trac 700
28.12.2016, 13:43
Good day Patryk
To help you better, it would nice to have the serial # from the trac .
Do you still have a plate on the axle with the axle ratio ?
Maybe add a picture if you can
Is the axle not repairable , what is wrong with it
I am sure someone has parts for you.
Kind regards Frank
.Is the axle not repairable , what is wrong with it
Kind regards Frank
chasiis number 440162 00 083171 rear right axel hub gets hot and the axel tube
sound like you got stones in it
28.12.2016, 19:49
Hi Patryk
Well, I would not drive it anymore
Take it apart, and maybe you get away with a set of bearing, but you can only see the damage when you take it apart . I do not think, that you have to get a '' new '' axle , parts will do it, since it is still driving.
At the same time, take a look at the oillevel on the other axle / portal axle.
Keep us posted .
Cheers Frank
Keep us posted .
Cheers Frank
28.12.2016, 20:47
(28.12.2016, 19:49)one of a kind schrieb: Hi Patrykofc i dont drive it any more and it is att least bearings but whit that sound and my luck it is mor parts that will be broken so that is why im looking for an axel
Keep us posted .
Cheers Frank
and i cant find any parts shop online for bearing and gaskit thank you for ansers =)
28.12.2016, 21:22
Hello Patryk,
here in Germany you can normally get all parts at "Mercedes Benz" repair shop, also if you have an old MB Trac 700. Every MB-dealer can look to the EPC (electronic part catalogue). If you need some part-numbers, i am sure some forum-members can help.
I am sorry, but i have no posibility of EPC.
In Southern Germany we have a good address for used parts:
Walter Kürsammer
Tulpenweg 20
89584 Ehingen
email: w.kuersammer@gmx.de
He also has a rear axle for you in ebay.de :
Hinterachse für MB trac 700 er und 65/70 Mittelschalter
http://www.ebay.de/itm/Hinterachse-fur-M...SwOyJX4M9e
Best regards from Southern Germany,
Franz Josef
Walter Kürsammer
Tulpenweg 20
89584 Ehingen
Franz Josef
10.01.2017, 19:17
Hello
I have a rear axle in superb condition for a 700 from that year. It is £750 plus transport. If you're interested do PM me. All the best, Paul
01.02.2018, 22:20
05.02.2018, 11:49
do you still hav the axel
05.02.2018, 14:45
(Dieser Beitrag wurde zuletzt bearbeitet: 05.02.2018, 16:27 von one of a kind.)
Good day Patryk
UK Trac 1100 900 was on line last night, but proberly did not read your question .
Write him a PN, hopefully you will see it .
Don't forget to sign your tread, give it a finish
Good luck, eh.
Frank
.Good luck, eh.
Frank
08.02.2018, 00:01
Hi
Yes i do have the rear axle for you
Sorry for not seeing your reply earlier
do email me at: gates@jamesautomation.co.uk
Thanks
Paul
Thanks
Paul
